where to find info on quadzilla products
Been trying to find good quality information on quadzilla products and can not. Even Quadzilla's website doesn't explain very well their own products. If I cann't find decent product explainations soon I'am just going to go back to my original plan and buy a Edge Juice/Attitude.
Xzillaraider Standard:
1. What are the power levels?
2. how are the levels changed or controled?
3. stand alone unit or need commander?
Xzillaraider Race:
2. How are the levels changed or controled?
3. Stand alone unit or need commander?
Commander:
1. Can it read and clear DTC codes?
I was told I can make the XZT adjustable with the commander. Is this true and if yes what levels are there in the XZT.
Now I've gone brain dead, I'll think of more questions later.
Thanks,
Xzillaraider Race:
Commander:
Thanks,
I don't know what you mean by decent info on the products. I have them listed in the store here and all your questions are pretty well covered except fot 2 of them.
XZT 65HP
Standard 30-60-100hp
Race 60 100 140hp
They are stand alone come with a digital switch to control the levels. You press the button up or down as needed. If you run them with the Commander you can adjust them with it as well as setting de fueling points etc....
Any more questions I will be happy to try and help you. if you need more specific info call Quads tech line at 1-888-842-6572...I hope this helps.
They are NOT programmers, so they will not read and clear codes.
XZT 65HP
Race 60 100 140hp
I can answer some of the questions
Standard
Level 1 30hp/90lbs torque
Level 2 50hp/120lbs
Level 3 100hp/200lbs
Race
Level 1 60/120
Level 2 100/200
Level 3 130/230 (04.5 and the 05) Older manual
Can't read codes, unless the commander can. Yes the commander can control the XZT 65hp/165 torque. To what degree I don't know.
Look around here a lot of info on their products
http://www.thoroughbreddiesel.com/qu.../xzt-seies.htm
Standard
Level 2 50hp/120lbs
Race
Level 1 60/120
Level 2 100/200
2. included switch or Commander
3. stand alone or can be controlled with Commander
2. same as above
3. same as above
No.
It doesn't.
I guess with the decent info statement I was meaning on quads website.
In the information I just got from you guys says different things from some.
I also just found on quads site (looked a little harder) that the commander defuels for transmission temperature.
This is what I mean about decent discription. one guy says one thing and another says some thing else.
Does anyone have pictures of the switch used to go through different power levels or describe it?
Does anyone know what the 20/30/65 programs are in the XZT when used with the commander? such as timing/pressure/duration?
Example:
20 pressure
30 timing/pressure
65 timing/pressure/duration
Thanks for your help,
Ron
Example:
20 pressure
30 timing/pressure
Ron
Example:
20 pressure
30 timing/pressure
Ron
Example:
20 pressure
30 timing/pressure
Ron
You're right, I forgot about warnings/defueling based on tranny temp.
Quad has a post breaking down the gains associated with each fueling attribute. Keep searching and you'll find it. But don't expect that kind of info from other manufacturers. Unless their box is pressure only or timing only they're not going to divulge that type of information.
