Where to find a DYNO in the Dallas / Fort Worth area?
Can anyone tell me where to find a dyno in the DFW area (the closer to Denton the better).
Thanks!
Thanks!
Here is the search page for Texas. http://www.dynojet.com/dyno_centers/...ive/index.aspx
I think they did one last year too, I wasnt able to go though...
Other than that, there arent too many around with the optical sensor we need to dyno diesels....
August 4th at Speedtech in Haltom City is a date being discussed right now for a DFW area dyno day.
I wanted to hit up the next dyno day just to get a baseline with my current setup...
Yep - HPP it is. They're the only ones around I found with the optical sensor. I have no idea what that means, but it sounds cool. I'll just tell my buddies it's something extra that's required cuz my truck has so much power.
They do 3 runs for $75. I'll plan on going Wednesday. I want to do 1 run stock, 1 run on level 5, and 1 run on the Hot setting.
Theres no tach/ignition wire to tap off of to get a reading like a gasser.
The optical sensor is underneath the truck and reads the crank pulley/dampner as it spins, they mark it tdc then set the sensor under there to read the rpms(some are magnetic, stick to the frame) Others are on a little stand.
berok
09-15-2010 01:41 PM
Lark
02-23-2007 08:28 PM
KatDiesel
17
11-06-2003 02:03 PM
Crawler
44
10-24-2003 07:46 PM
