Where to Buy Longer Control Arms?
Well I just got done installling a Hellbent Steel 2" leveling kit, Bilstien shock absorbers, and the drop bracket kit for the anti sway bar. I would like to run 35" Toyo M/Ts and I think I will need longer Control Arms to re-center the front wheels. So my question is where is the best, most economical (cheapest) place to buy control arms that are longer to center the wheels?
Just curious, how far off center are your wheels? Are you having rubbing issues?
I'm not sure where to buy "cheap" longer control arms. But you might want to check out Tuff Country. I put their 4" lift in a few years ago for well under $1k, I can't imagine the control arms being overly expensive. http://www.tuffcountry.com/
Well there should be no problem finding them. Cheap may be the problem
http://www.thurenfabrication.com/controlarms.html
http://www.thecarlisuspension.com/do...ntrolarms.html
http://sourceautomotive.biz/dodgeadj...ntrolarms.aspx
http://lorenzindustries.com/products_arms.html
There surely others by rancho, tuff country etc
http://cgi.ebay.com/ebaymotors/03-09...Q5fAccessories
Thanks
Thanks for all the great info! Maybe I should have been more specific... I meant economical (we're on a budget) this should get me started. The front wheels need to be pushed forward about 2 inches to be centered in the wheel well. Thanks again.
I'm not sure if you can push the front end that far forward, there's too many parts connected to it to let that happen (sway bar and drag link come to mind). I don't think I'd go further than 1" forward....
Sorry
Sorry I have been in the Hospital this past week (my wife has our baby boy on Monday and he had to be in the NICU) I was wrong I just went of of memory. It looks like if the control arms were between 1/2" to 5/8" longer it would put the tires back to center. Thanks for all the responses.
Be careful about pushing the axle too far forward as it will rub up against the steering stuff.
silkywoods
14
04-29-2008 12:35 PM
Captain
02-12-2008 02:18 PM
Scramblinman
10-16-2006 05:36 PM
