Where is the best place to install a GDP filter and F/W separator?
I want to increase my fuel filtration with a 2 micron system from GDP. My 03 has the APPS so the under the air horn application does not work. I don't want to use the frame rail by the front tire or by the transfer case. I already have a stand alone FASS 95 ahead of the left rear wheel - I don't know if I can get the new filter and F/W to fit in there was well. Anyone tackled this problem yet? Any pictures of your setup would be more helpful.
My filter placement
I placed mine on the inside of the frame rail about even with the middle of the driver's front door. Easy installation and access when changing filters. If you do a lot of 4 wheeling mounting the filters there could be a bit exposed. Most of my driving is on the pavement. Need the 4 wheel drive for the snow conditions when I go north, way north.
L8r,..........dogger
truckjunkie
12-29-2010 04:45 PM
GaCamper
01-11-2009 07:05 PM
