whats safe to stack with the edge juice/add to make more smoke!?
ive been tryin to get info on what i can stack with my edge juice with additude to blow more smoke that is safe and affordable and im curious to see what yall think would work?!?! i appreciate your feedback. thanks!!!
I currently have the 05 ram and have the edge juice wit attitude. I heards good things about bully dog so I went out and bought the bully dog power pup. Tell you the truth it has been a good stack with my truck I run the power pup on the exteme setting 130 and the juice on level 5 which is 230 horse combined, let me tell you there is a very thick cloud of smoke untill the turbo spools up and when it does I break the tires loose untill 5th gear. But it is hard on the turbo to keep up and hard on the clutch. I will soon be upgrading the bully dog to the crazzy larry setting and updating to a dual disc clutch. I don't know how well the crazzy larry setting will work with the juice might be a bit much duration but then again it might be ok. But so far I like the juice and bully dog stack. All the saftey the attitude has and the the performance the bully dog offers.
well see i tried to stack to edge j/a with the power pup and i kept getting unknown vehicle when i tried to install it. i might try the super chips and see what that does. i hope it doesnt say the same thing. and if it works i hope i get the same results u got with the bully dog!!! what do u think??
Like I said I like the bully dog edge juice stack. Maybe something is wrong with your programer I don't know. I had the edge juice first then put the bully dog on no problems. I haven't downloaded the crazzy larry version yet as I am to affraid with the stock turbo and stock clutch. But in moderation the bully dog and juice is a good stack.
i dont have the edge but when i had the older version of the power pup every once in awhile it would come up as truck unrecognizable...i then sent it in and got the crazy larry program and all has been good
cj5er
0
10-05-2009 08:04 PM
white250005
10-25-2007 10:19 PM
VikingDiesel
11-15-2006 12:24 AM
12valveford
10-24-2006 09:25 PM
razor6
22
01-20-2006 03:43 PM
