Whats better? injector tips or whole injectors?
My setup is in signature. whats better? just injector tips or whole injector replacement ? Would I need a bigger turbo then?anyone lap the injectors themselves or change tips?
Just so you know FASS system coming in a few months
ok whats a good tip? 50 hp 100 hp etc.. and what name brand? Do you just replace old ones with new ones or do u have to lap them together and change spring tension/shims?
all i seem to find even on ats site is whole injectors for $200 a piece. How much just for tips? and what kind? If you run the 100 hp tips you probably need more than a edge juice and a cp3? right?to pump enough for them?
When I do my injectors im going with some F1s, since Don goes through the stockers and makes sure everything is perfect before sending them back. There are otheres that are good like DDP, or II, but they only sent tips. So if you have a bad body, you can run into problems. I figure if Im in there i may as well make sure everything is perfect.
If you don't want to spend the $$ on a cp3, you may be able to get away with just a dual feed line. You'd have to have a rail pressure gauge to be sure, though. Aside from the Juice, you may benefit from a pressure box like the EZ...
sallyman1
02-03-2009 09:23 PM
01DodgeDiesel
08-24-2008 08:56 PM
KevinH78
11-21-2007 01:31 PM
THURENfab.
60
08-21-2007 03:19 AM
Suneview_Farm
05-13-2007 10:58 AM
