What year did Cummins come out with variable vane turbo?
ok thanks. If I bypass the wastegate by clamping hose or taking it off will i overboost? I want to rule out whats wrong with my edge and high egt problem
What power level are you running it on? Looking at your signature if you are running it at level 4 or higher I would expect to see EGTs of 1400+ pretty quickly. Sounds like you are a candidate for a turbo upgrade. If you are going to disable your wastegate be careful. Dont go more than 40psi of boost with it. At that level it really isnt going to be efficient at all. It will just pump hot air, but you also have to worry about them blowing up anywhere after 40. I know some guys run them higher, but I have seen them pop at 42psi.
Guess I'll try again.
Send it in!
Send it in!
Send it in!
Send it in!
Send it in!
Send it in!
Send it in!
Send it in!
Send it in!
Send it in!
Send it in!
You should see 40-45psi with the Hot Juice.
Send it in!
Send it in!
Send it in!
Send it in!
Send it in!
Send it in!
Send it in!
Send it in!
Send it in!
Send it in!
Send it in!
Send it in!
Send it in!
Send it in!
Send it in!
Send it in!
Send it in!
Send it in!
Send it in!
Send it in!
Send it in!
Send it in!
Send it in!
Send it in!
Send it in!
Send it in!
Send it in!
Send it in!
Send it in!
Send it in!
Send it in!
Send it in!
Send it in!
Send it in!
Send it in!
Send it in!
Send it in!
Send it in!
Send it in!
Send it in!
Send it in!
Send it in!
Send it in!
Send it in!
Send it in!
Send it in!
Send it in!
Send it in!
Send it in!
Send it in!
Send it in!
Send it in!
Send it in!
Send it in!
Send it in!
Send it in!
Send it in!
Send it in!
Send it in!
Send it in!
Send it in!
Send it in!
Send it in!
Send it in!
Send it in!
AGREE^^^^^
