What will stack with hot juice and EZ for '05
I believe the stacker tunes on the predator remove some timing. Designed to stack with the puck which is timing I believe. Or maybe i have that all wrong. Im still playing with my diablo/juice and stacking. Works well together on lower settings. I need a tranny and fuel system to play with the big power.
I've seen in more then one instance that the Smarty and Edge dont get along! Why not a Smarty and a PSI Box! I understand if you already have a edge, With the power you'd like to make, I'd say the smarty and a PSI Box would be a better setup!
hot juice/ez stack
i finally dynoed today at fall brawl and put down 507 HP and 963 ft-lbs TQ with a edge hot juice and ez stack with stock sticks, cp3, and turbo! time to go bigger!
Well you have about maxxed out what the Hot Juice/EZ stack will do. You can get maybe some more with the right downloader, but with your mods I would sell the HOT Juice/Attitude and get a TST. You will have many more options for downloaders and will make more power with the TST by itself. At least that was my experience with the Hot Juice/EZ stack. It was a great stack for me, but just got to the point where it was not going any higher.
white250005
10-25-2007 10:19 PM
morkable
09-28-2006 06:50 AM
razor6
22
01-20-2006 03:43 PM
duallydave
08-07-2005 09:38 PM
