What the ticking sound under hood when u turn key forward?
The vacuum pump does make noise ocassionaly, but I am sure you are hearing the injectors cycle lieka few folks have mentioned. Mine will do it everytime I turn my key to the on position and has for the last 108,000 miles.
I didn't think any 3rd gen had one? Or are you referring to an elec one?
Is the noise on the passenger side near the firewall?????
Does your cruise control work properly?
It may be your vacuume pump running, may was makeing all sorts of noise due to the line being split and the pump was not mounted properly due to the install of the exhaust brake.
On the passenger side behind the battery from what I remember. It is used for the cruise control only to actuate the dashpot for 03' to 04.5' trucks.
You can get a clicking sound when you first fire a truck up and yes it is due to air purging out of the system unless you have an Airdog like I do and you don't get that noise anymore
I get a noise from the passenger side firewall near the glovebox anytime I unlock my doors it seems like. First thing in the morning when I unlock and open truck I can hear something near the glovebox, and it will do it if I lock and unlock the doors again? I'm an 06, so no vacuum pump. Anyone have any ideas? This morning I actually heard it more towards my radio, it almost seems like it's the HVAC actuators moving?
nvr-enuf
14
04-20-2013 12:59 PM
1985cucv
04-11-2010 10:42 AM
sallyman1
08-28-2008 07:21 PM
blackwolfram
05-26-2007 01:26 PM
Dodgezilla
02-13-2004 03:40 PM
