What the ticking sound under hood when u turn key forward?
Old 02-16-2009, 08:21 PM
sallyman1's Avatar
i have a lift pump in tank on my 2004.5 . i bought truck used but I think it was updated. you can hear the lift pump at rear of truck. but under hood i hear clicking sound when key turned forward before i start it. it doesnt sound like grid heater. sounds like its coming from fuel anister. is it the fuel heater.it goes tick, tick, tick , tick for ever until i turn key to start truck.
Old 02-16-2009, 08:40 PM
sallyman1's Avatar
any1? kinda sounds like the electronic igniter on barbeques now a days. except constant. i cant pin point it. its not a problem im just curious as to what it is. is it a coil producing enough voltage for grid/fuel heaters?
Old 02-16-2009, 08:47 PM
trksrfun's Avatar
how often does it "tick" it might be your grid heater kicking on and then off but cant tell for sure.... park the truck in a dark spot at night turn the key and look under the hood make sure its not something arcing, reason i say do it at night in the dark cause you will prob see the spark light up
Old 02-16-2009, 08:50 PM
CallmeD's Avatar
just heater
Old 02-16-2009, 08:51 PM
Rod_Montana's Avatar
My buddies 2004.5 also does this. His original lift pump failed and he got the in-tank one installed under warranty, but still sounds like the lift pump working up forward. One of these days I am going to check and see if the old pump is still there, but disconnected.
Old 02-16-2009, 08:58 PM
sallyman1's Avatar
lol. exactly. its weird.
Old 02-16-2009, 09:02 PM
CallmeD's Avatar
If you look at your dash you'll see a coil symbol illuminated while you hear the ticking. Once the ticking stops you'll see that symbol go off. Then you start your truck. I never wait as its not cold around here.
Old 02-16-2009, 09:03 PM
Keyser Soze's Avatar
Mine does it and i got the heat grid delet kit, i have the wires wrapped in electric tape and everything and it still does it..
Old 02-16-2009, 09:06 PM
CallmeD's Avatar
hmmmm dont know then
Old 02-16-2009, 09:11 PM
chrleb1's Avatar
It is the injectors. It's part of the test procedure of the ECM. It just fires off the injector solenoids. It's totally normal... no worries.
Old 02-16-2009, 09:26 PM
loafus's Avatar
ya i agree, mine does the same. it is normal.
Old 02-16-2009, 10:24 PM
Administrator/Jarhead
madhat's Avatar
Mine does too... Just purging air...
Old 02-16-2009, 10:45 PM
SjLingenfelter's Avatar
thats correct its the injectors testing their selfs
Old 02-17-2009, 02:05 AM
vj_M's Avatar
injectors.
Old 02-17-2009, 04:11 AM
sallyman1's Avatar
lol. i guess it could be. next time ill put my ear on valve cover
Quick Reply: What the ticking sound under hood when u turn key forward?
