what is a swiss cheese air box?
Old 05-09-2006, 06:06 PM
thorbuilt's Avatar
I have read a few people have these? What are they?
Old 05-09-2006, 06:21 PM
Dodgezilla's Avatar
You pull your air filter out of the airbox and get a hole saw and drill a bunch of holes in the bottom of the air box. This will give you better airflow. Some have even drilled a 4" hole in the bottom and installed dryer venting and made a homemade Ram Air setup. Just don't try drilling holes in the top of the airbox!!!!
Old 05-09-2006, 06:46 PM
VikingDiesel's Avatar
now yu tell me
Old 05-09-2006, 08:03 PM
Dieseljunkie's Avatar
Something I have yet to do... Any particular size holesaw to use with this? Ive got one thats about 2.5" in diameter.. any reason this won't work?
Scott
Old 05-09-2006, 08:26 PM
tantruck's Avatar
Holes in the bottom of the box - be careful!!
I had originally used a 1 inch hole saw and drilled between the ribs in the bottom of the air box. About 20 holes I believe. It's easy to take the air box out, however if you don't pleasse be careful and don't puncture the a/c line under the box. Just my 2 cents worth.
Old 05-09-2006, 08:40 PM
Dodgezilla's Avatar
Look at the little squares in the bottom of the box and try to use a hole saw or regular drill bit that fits inside the squares or you may end up with a mess on your hands.
Old 05-09-2006, 09:10 PM
Ok.. Ive got a few smaller hole saws as well.. I will definetly take the air box out.. can't see any reason no to.. maybe I will do it this weekend.
Scott
Old 05-09-2006, 09:32 PM
Dodgezilla's Avatar
Just don't press too hard while drilling or the bottom of the airbox may break! That's what I did on my 98 CTD......
Old 05-09-2006, 11:32 PM
Its only plastic, it shouldnt take that much pressure to blow through the box..
Scott
Old 05-10-2006, 08:12 AM
Reel Native's Avatar
For you "cheap skates" (just kidding, I did my box to but have a Scottys 5 now) dont forget to remove the small rubber deflector next to the pass headlamp that connects to the AC condensor. (unless you live in snow country).
Old 05-10-2006, 08:46 AM
dhe9's Avatar
cutting da cheeze
so when one drills out the air box will one see an improvement in tq, hp, sound, or mpg? i have a 20' magnaflow and need to do something with the intake.
thanks,
david
socal
Old 05-10-2006, 08:58 AM
thanks,
david
socal
a little bit of everything, lower EGTs too
Old 05-10-2006, 10:05 AM
Dodgezilla's Avatar
I, personally, did not see any of the gains some members claim to have gotten. It made me feel better though.....
Old 05-10-2006, 10:12 AM
wierd
with only the swiss cheese mod, i shaved at least a couple seconds on the 1/4mile, I was at like low 12s with 1/2in holes and mid 11s with the 1in holes so then I decided to forget everything and make on GIANT HOLE, now im bordering 10s. SWEET MOD!!!!
Old 05-10-2006, 12:11 PM
Dodgezilla's Avatar
Um, 10s in the 1/4 mile???
Quick Reply: what is a swiss cheese air box?
