What is the stock turbo model number on an 05 CTD? Whats the best upgrade?
Hello !
Is the stock turbo a HX-40 ? on an 05 model?
What whould be a good upgrade to increase power and torque while reducing EGT's ?
THanks a bunch
THanks a bunch
Usually adding power and reducing egts dont happen together. I have heard that the bullydog downloader on the tow setting (50hp) runs a little cooler than stock. Not sure about the turbo numbers. Sorry.
You can actually reduces EGT's with some boxes on the lower or tow settings. My truck runs a little cooler on the tow setting than it did bone stock. Stick with a box that alters timing. A duration only box will make EGTs very high. I've read that pressure boxes on the low settings have also dropped EGTs when stacked with other boxes (ex. - TST with edge ez). Air intake/exhaust mods will help a little (50-100 deg maybe). Other than that you would need a bigger turbo or intercooler or both.
a 04.5 is a he351
http://www.holset.co.uk/files/2_2-applications.php#
I thought the 05 went to a bigger exhaust housing compared to the 04.5.
MoparRiggin how do you like your TST/BDDL stack and what settings do you run it on. Lmills over on TDR dynoed out at 598 with this stack and twins.
05mxdiesel, I really like this stack. I run the Bullydog downloader on the 90hp setting and the TST at 1/1 up to 4/4. I need to install a fass fuel pump b/c at the 4/4 setting I start to run out of fuel
04.5 turbo,...what the heck here
Originally Posted by marc03
a 04.5 is a he351
Originally Posted by OT-OF-Here
Also I know I've seen this on this forum and TDR that the turbo for the 03 and 04 is an hx35. Help anyone??
hovisimo
19
03-24-2008 08:57 AM
RedRam410
02-02-2007 10:27 AM
WACTD
03-21-2006 12:08 PM
00turbo
09-14-2004 07:17 PM
Bart Timothy
06-30-2003 03:55 PM
