what is a "soft" code?
Not sure what you ran across. But there are some codes that are referred to as stored codes. They were set at some point because of a condition and stay in stored code memory until reset.
I would call a soft code a code that only shows up when you read the ECM with a scan tool...a soft code does not turn the CEL on....I had them when my AC door broke..only showed the code when I hooked up the scanner....and NO CEL
HA!! Soft core. You dirty, dirty man. I like you. I put a grid delete and an air horn on my truck today. I did not get a CEL. I was just reading up on stuff and ran across the soft core...umm code term.
Thanx guys.
Thanx guys.
PEAKSTRYDE
10-11-2007 04:20 PM
FireNhole
12-31-2002 10:56 AM
JoeDiesel
12-24-2002 01:26 PM
