At What setting is a pusher pump needed with TST BDDL Stack?
Hello everyone,
I like running my BDDL on 90 HP and the TST on 4/4
At what setting on the TST is a FASS fuel pusher pump needed?
I have had my 05 CTD hick up a time or two with the bddl at 90 and the TST at 4/4
I was told that it hick upd or bucked because I was running out of fuel at the injection pump.
Also Ive heard people stacking the TST with the BDDL Crazy Larry program and getting cooler EGT's ?
Is this true? How smooth is the power with the crazy larry stack and TsT?
My truck is stock except for AFE intake , No Cat , Nelson 86131M muffler, Metal intercooler, and of course the BDDL at 90 HP and the TST at 4/4. Also just added ATS torque converter and flex plate. The OEM flex plate came apart so I upgraded to the ATS converter and flexplate.
Thanks
Thanks
If you are experiencing hic-ups, then you have vacuum in the line. My gauge used to run on 0psi but wouldn't hic-up until I really got on it and actually sucked the line dry. And trust me, when that happens, your asking for a HEAP of trouble! I'm in the process of having my pressure relief valve replaced and swapping out my Carter pump for a 95GPH FASS.
Mark at TST will also tell you that anything under 6psi in the delivery side will cause a lack of hp with the PMCR. That's even without any kind of pressure added.
So, in answer to your question, even if you ONLY run a TST, you should STILL run a good pusher pump. Whether it's Airdog, FASS, DPP or something of equal quality...
the 05s have a different system,the pusher pump is not only better but in the tank now as well.also these cp3 pumps work just fine pulling negative vaccum as long as you dont go above -3 your fine.i run my cldl,tst on 5/3 and ts powerplat at wfo no hickups or burps
I mounted a Holley blue pump right at the tank and it made a huge difference in the power of my truck. I also have a TST powermax 3 stacked with a NADP HEavy Hauler, lots of fuel now, no hiccups.
King d...it might "run" fine...but how can you explain that I can make 550 hp with only a special Ramifier and a Twins TST on a big single and you have resulted to triple stacks and still have not dynoed that high (or maybe the same now...lost track). I was down 100 hp before my fuel system was fixed with a Scotty Smart fuel...
I have had mine hip-up with the crazy larry/tst stack, so I'm installing the FASS pump. I spoke with Mark at TST and he said that running his box over 4/4 would suck the line dry. As far as the 05 pump being better, Mark seems to think they are worse.
Get a FASS or Holley.
You'll be pleasantly surprised with the results.
After I added a FASS to my truck it felt like I had another 20hp on the bottom end!
one more thing just came to mind,i havent installed the banks intercooloer yet,so i still have plastic end caps,i am wastegated at 40 psi and i can still smoke coal black at 40 psi,add some nos and its a different story
Topper
03-03-2008 10:17 AM
LooseBoltsRob
17
06-10-2007 08:52 PM
WhiteSport600
12-23-2004 09:59 AM
