What to put on injector o rings and washer?
Old 02-07-2009 | 08:56 AM
sallyman1's Avatar
do u put 15w40 engine oil or lubriplate or vaseline on injector orings on our 5.9s? synthetic or not? also on the washer do you just put it on tip or do you put a little never seize just to keep washe from falling off tip when installing?
does any1 wire brush injector cup/holder and vacuum filings out before putting new injector in? what size wire brush cuz ill go buy 1?
Old 02-07-2009 | 09:25 AM
bluechrome's Avatar
Do not!!! Put any thing on the tip(nozzle)!! If you want you can put a little oil on the oring to assist in the install
Old 02-07-2009 | 09:54 AM
mopardamo's Avatar
Hello,
Do not risk vaseline. There was a time when it would deteriorate some types of rubber. Don't know if it is still true.
Damon
Old 02-07-2009 | 10:09 AM
bob4x4's Avatar
Engine oil or diesel on the o-rings,a lil grease to hold the copper in place.Snap on sells injector bore brushes,but I haven't seen a 3rd gen that needed any cleaning there yet.
Bob
Old 02-07-2009 | 10:18 AM
05CTDN8's Avatar
I agree, i would only use your standard engine oil....I would not even risk any grease on there!!!
Oh yea, not to flame...but please just re-read your post and see if you can completely comprehend what it is saying.
Old 02-07-2009 | 01:57 PM
sallyman1's Avatar
yes u r right. i didnt mean tip i meant where the copper washer goes.wont the ring fall off if theres no grease or never seize holding it on?
Old 02-07-2009 | 06:22 PM
coblanchard's Avatar
A little grease to hold the copper seal in place isn't going to hurt anything.
ahire
13
10-17-2008 12:50 PM
BigErksG2
09-25-2008 06:43 PM
12VRoush
10-15-2007 08:00 PM
1320
03-08-2005 08:56 PM
Quick Reply: What to put on injector o rings and washer?
