At what point do you need an Opies bypass?
#49
Winner winner chicken dinner!
I am not at all being smart but from a good source opies kit is above and beyond what the average person can get. Not saying it's not an easy kit to build but apparently you cannot get the valve he uses. It works off both pressure and temp and was picked out for that reason. Anyway I still say if you are going to run your truck hard you need some type of bypass.
#52
Well, I don't have a never ending wallet - the thought of a BIG repair bill due to the damage the overheating in the rear of the block causes and the pressure stuff blowing that rear freeze plug is what motivated me into installing the OPIE. EIGHT GRAND + engine - $400 was a SMALL price to pay for some insurance.
While there might be a cheaper way to do this, the OPIE has been proven, I am not into experimenting with something that could end up costing me a whole lot more in the end game.
CD
CD
#53
Can get the same insurance with other kits for alot less. Myself I prefer a kit that takes pressure where it is the highest at the rear freezeplug. My kit is not as pretty but It works and I think better then relieving pressure from around the corner and halfway up the head. Maybe not but just my opinion.
#54
well there is a ton of guys running them in high high horsepower applications so you be the judge. if i had the money yeah i would buy the opies kit but i do not
#55
I am still wrapping my head around why there has to be such a cost involvement behind this. The 3rd gen 5.9 internal casting back at cylinders 5 and 6 have a choke point that does not allow the return flow to be as good as the rest of the block. When you push the power it creates too much internal pressure in the back of the block and blows freeze plugs. It can happen on the older blocks also, but it takes more to get to that point. The reason for the by pass kit is to have a pressure relief point so freeze plugs don't get blown out. By no means am I an engineer or diesel motorhead that knows the 5.9 100%. But, if there is a choke point back there already because of the design, then why not just do the bypass without the relief valve? Would it disrupt proper cooling back on cylinders 5 and 6 if it didn't have the relief valve? If that is the case, then when the bypass lets pressure relieve, you would disrupt the proper cooling anyhow. But, I guess it would only be for a very short period vice all the time.
#56
#58
I dont know if this answers your question but if you ran a bypass with no valve it would basicaly be like runnin with no t stat, and your truck would never warm up. I ran with a barp clipped off my tstat, wich is leaves a very small hole and it took forever for the truck to warm up even in the south in the summer.
#59
other guys who sledpull get there trucks warmed up and then open just a normal valve to allow full flow and a full bypass, that way they arent seeing high pressures either!
#60
Hello,
I am a bit foggy on this whole pressure vs temperature thing. It is a closed system. As I understand it the boost pressure should not play a role. It is the pressure generated by the mechanical water pump. So when the coolant is relatively cold(higher viscosity) and you get on it the likelihood of raising the pressure is greater at this choke point. So why does HP play a role in the recommendation to get a bypass system? I can see rpm being the big driving factor.
Damon
Damon
