What are killers of injectors?
Old 09-17-2007, 07:54 PM
2007 5.9's Avatar
What are the main causes of injector failure?
What is ideal Rail Psi?
Does duration kill them?
Old 09-17-2007, 08:00 PM
BigTXDually's Avatar
Well the worst killer would have to be slapping one with a piston. That teds to screw up a lot of stuff. Dirty fuel is a BIG one, o while back it was posted on this site that Bosch recomends filtering your fuel down to I believe it was said to be 2 microns. Thats what i run in my FASS at least. Yes excessive pressures can kill an injector too, infact thats how i killed 4 of mine. As far as normal rail pressures im not sure there is a lot of info floating around on that.
Old 09-17-2007, 08:03 PM
2007 5.9's Avatar
What pressure could be considered excessive?
Old 09-17-2007, 08:34 PM
CReed's Avatar
Bosh has reported testing their injectors to 29kpsi all day long without failures this was directly from ts performance website and they got the info off of bosh's website. We have been told by several injector companies that injectors can take 30+psi for limited amount of time. They also said that its more spiking effects that damage and crack injectors, they said it like this its like an empty coke can if you start to crinkle it over and over again eventually the can will crumble. Bad fuel is a huge cause especially now days with lots of companies cutting corners here and their just to save a few bucks.
Old 09-17-2007, 08:47 PM
Ramtuff06's Avatar
bad fuel will kill injectors big time. jet,#1, and ?jp-8? killed my daddy's injectors in his brand new 07 ,as a good son i told him not to put his "homemade" diesel in his truck but he did anyways, now he blows white smoke and rattles bad, dealership said he had water in his tanka six gun,smarty,and a heavy foot didn't help either
Old 09-17-2007, 10:09 PM
jfranklin's Avatar
i run a fass with 3 micron filter and stay away from the pressure boxxes...
Old 09-17-2007, 11:37 PM
#2 only's Avatar
Yes all of the above.Pressure is not good, but to be more specific on dirty fuel,let's take a look at what's in our fuel.I tried to attach a video, but it won't let me.Pm me and I'll send u a video that shows what is flowing thru your injectors at 20,000-30,000psi.
Old 09-18-2007, 09:07 AM
jrussell's Avatar
I think the main cause of injector failure is, installing them into the engine. They seem to last a lot longer just sitting on a bench somewhere.
Old 09-18-2007, 10:37 AM
AlCorr's Avatar
I'm running a Baldwin 5 micron (PF7977) in the stock filter housing and haven't had any injector failure.
Old 09-18-2007, 10:41 AM
ptgarcia's Avatar
That'a good one! Then I'd have to say the #2 cause is dirty fuel. At 20,000 p.s.i. it doesn't take much dirt to destroy an injector.
Old 09-18-2007, 11:13 AM
#2 only's Avatar
The oem and aftermarket 2 micron filters takes care of the dirt, but not the metals.Think about metal flowing into the filter housing.Metal , unlike dirt or other debree is very sharp.Metal WILL makes its way past the filter(10,5, or even 2 micron)A 2 micron filter is a terrific add on but, it won't stop the metal.The fuel strainer will.
Old 09-18-2007, 11:46 AM
rynemurch's Avatar
Originally Posted by #2 only
The oem and aftermarket 2 micron filters takes care of the dirt, but not the metals.Think about metal flowing into the filter housing.Metal , unlike dirt or other debree is very sharp.Metal WILL makes its way past the filter(10,5, or even 2 micron)A 2 micron filter is a terrific add on but, it won't stop the metal.The fuel strainer will.Pm me w/your e-mail if u r interested to c a video.
Thats a awesome video clip I think evertyone needs to see it!
Old 09-18-2007, 11:51 AM
cbrahs's Avatar
Location: misplaced Idahoan stuck in Albuquerque, Roughneckin on RIG 270
ya it is very interesting. thinking of finding one of those things and getting it installed asap.
Old 09-18-2007, 12:39 PM
XLR8R's Avatar
Injectors operate at water-jet cutting pressures, so impurities in the fuel certainly cause death by abrasion.
IMO, corrosion is a significant - if tertiary - accelerant of MTBF in electrically pulsed injectors. Considering the tip material/fluid medium mix, I don't think dissolution is possible.
No doubt severe pulsing creates hydrodynamic spikes that cumulatively fracture injector tips and initiate shock-induced crack propagation from micropitting caused by erosive particles.
Of course, the high combustion chamber temperatures elevate the tip alloy quite a bit higher towards it's range of plasticity...
Sticks lead a tough life!
Old 09-18-2007, 04:53 PM
bighornram's Avatar
^^^^^^ How many engineering degrees do I need to be able to use that many big words in one sentence?
Quick Reply: What are killers of injectors?
