what injectors??????????????
i running a 2004.5 4x4 auto with edge with ATT and straight pipe. I'm wanting to get some injectors, torque converters and valve body. i tow a trailer ever so often that weighs 10,000-12,000#. i was thinking ddp 90 hp and run the edge on stock when pulling the trailer. what do you think?????? would i need a fass pump??????
You are gonna need a turbo if your gonna run them both together to keep the temps down. Also defiantly a fuel system, but as for pump and studs I don't think so as long as your not stupid. I am currently running a stock pump on my setup but will soon get a modified one when I get the money. As for stud there are plenty of guys that are running bigger turbos with no studs so I think you'll be all right there.
and not really having egt problems unless i bump my quad box up to 100 and my daily smarty is at 7.
My next move is to upgrade to the bd twins or sell super B and get mpi twins and then i think i would be ok with my egts and 90's?
darrenG
06-21-2005 10:24 PM
