What is the highest hp dyno'd on stock injectors on a "600"?
CLDL and TST
Originally Posted by abc4yew
Guys, That is why the Crazy Larry works so well with the TST...lotsa timing. A buddy at my diesel guys shop runs a sledpuller 66 TST and Crazy Larry and he can run 9x9 no problem...and the smoke clears at about 60psi and it rips through 6 inch mitre stacks. He was points leader in the Ontario Canada Sledpulling this year.
Stroke, You will be close to 440 if you have a good air supply...Bhaf or other...and You can get the power through the stock tranny 450 with the decal polished. Without big timing and duration and a built tranny... 500 is a hard jump.
So 450hp. how much tq do you think i will make with CL?
Ot, Greg runs the crazy larry on crazy larry and the TST twins on 9 9 for final pulls. It sounds like a machine gun for a second or two and then the sound deepens and deepens and the smoke goes less black and then you'd think you just heard a train go by. It's impressive. ks
Stroke, That will cost you a $100....at the dyno.....getter done!!
Guys, Here's what Greg's truck looks like with turn backs on. ks
http://www.hotroddiesel.ca/Greg%20Kidd3.jpg
Originally Posted by nojodas67
forgive the stupid question; I'm new at this. What (or who) the heck is "crazy larry"?????
Crazy Larry
I run Crazy Larry, TST "twins" and Edge EZ... Mine pulled the 541rwhp on stock injectors w/HUGE wheels & tires, TST on 7/7, no drugs on a Dyno Dynamics machine (lowest readings out there). The dyno operator said that it would've been around 575 on stock tires. I'm going to re-dyno soon on a Dynojet... once w/nitrous, once without. You'll have a hard time making over 480's on a stock turbo though.
you lost me, what is turned on?
I will have to run mine on some stock tires again and see if I can get them to stick to the Dyno... Should be impressive for Stock Turbo, Fuel, and injectors... But I definitely know what is on the way...
[B]My first CTD - Please Help [/B]
Ok I finally broke down and bought my first CTD. I purchased a used 2003 2500 SO Cummins Quad cab, long bed for pulling my car trailer around. I switched from a gas powered ram to the cummins. I had expected a lot better pulling power than my 2000 5.2L ram, but was a bit dissapointed after the first trip, although fuel economy is a little better; I've been reading alot about mods that can be done but the more I read, the more confused I get. This is where I say "HEEEEEELPP". "I don't know where to start".
I'm not looking to peel the treads off my tires here, I would just like to have some spare horses available that I can hook up when I need them; say when going up the rockies pulling a 5,000 lb. suburban on my 2,000 trailer.
A CONSICE AND HONEST ADVICE FOR A NEW CUMMINS OWNER WOULD BE GREATLY APPRECIATED. Again, I just want to do the minimal for the most HP/TQ gain that will be safe for the engine and won't cut too many years off it's long life.
And btw, the truck has just 30k so it's just broken in, and it's all stock.
Thanks to all in advance.
Originally Posted by chw
ramwb4, just curious but are you still running the bully dog stack are just the tst and ez?
