What is the highest boost on stock tubo with bddl &TsT?
What is a safe amount of boost ?
I have an 05 CTD with the Bddl set at 90 hp and TsT PMCR at 4/4 and i can see 40 lbs of boost on the TST easily. Im not sure if the TsT will only read up to 40 lbs of boost. I might be getting higher that 40 Im not too sure.
What is the highest safe level on an 05 CTD with stock turbo ? and Is there a way to put a resistor in the electronic waste gate actuator to limit how high it can go?
At what point do you think head studs are needed?
I have the AFE Stage 2 intake with the new 6 " air filter outlet and this thing really sounds like a jet airplane.
Im a little scared it might take flight !!
Thanks for the input !!
1 Post
Originally posted by lit up
can hit 51 psi..........
Originally posted by MonroeDiesel
......would'nt your drive pressure be really out of wack its only a 9cm turbine!
![EEK!](https://www.dieseltruckresource.com/forums/images/smilies/eek.gif)
![Big Grin](https://www.dieseltruckresource.com/forums/images/smilies/biggrin.gif)
txsbigdaddy
56
09-18-2007 04:29 AM
LooseBoltsRob
17
06-10-2007 08:52 PM
Ramirezh
02-04-2006 04:41 PM
WhiteSport600
12-23-2004 09:59 AM
