What is a good towing Turbo
Old 10-26-2007 | 10:41 AM
ptgarcia's Avatar
Originally Posted by kantdrive55
Have you taken a look at our Super B? It will flow enough for 450-500hp and then down the road if you want you can upgrade it into the twins. Then the options are wide open for power.
Pat,
How much fuel do you need to feed the Super B to get it to light? Will it spool well on a stock truck?
Old 10-26-2007 | 07:47 PM
Agades's Avatar
I ran a Phat shaft 62/14 for a year
It was NOT a good towing turbo unless you are pulling over 70 mph
I could not pull heavy (18,000 gcvw and over) in overdrive at normal highway speeds without egt problems
this turbo does not have enough drive pressure at normal speeds
I had to drop a gear and suck a LOT of fuel
I am now using my stocker
great turbo for rompin around and grocery gettin though
for towing heavy loads, look for a turbo with a smaller exhaust housing
like 12cm;-)
Old 10-26-2007 | 07:55 PM
Agades's Avatar
the money I have spent on turbos since buying my 03 truck,
only to be dissapointed by false claims,
I could have easily put in a set of Nathans twins and from the sounds of it , would have been happier
Old 10-26-2007 | 08:27 PM
PowerDually's Avatar
like 12cm;-)
I had the same problem with my HTT super stocker which is a 62/14/71 and had to drop a gear down to fifth when hitting hills but when I added the PPE downloader and a Dr P stage 3 for pressure I lost that problem forever. EGT's were very manageable.
The 14 housing is a dog when you go from the stock 9 housing. With out some low end pressure it takes forever to spool. I tried other combos and stacks but nothing was as good as the one I am using now. Mild and I mean very minimal lag but lights right off and pull like now tomorrow.
I pull a 13 K dry weight 5ver with all the stuff for full time living in it so I am figuring around 15K-16K total weight. 100 gallons of diesel inthe truck inclusing a full trunk tool box and custom bumpers and headache rack should probably put me around 24K total weight. This turbo pulled it no problem runnin a bit over the speed limit.
Old 10-28-2007 | 11:13 PM
wardy70's Avatar
Ive looked at a few turbos like I said just wanting to get some opinions. I dont know a lot about them and just wanted to find out what everyone is using towing similar weight as I am. Can I still use my downpipe I have now I have a 5in magnaflow exhaust? Is pretty much a bolt in replacement for the stocker? Would I have to immediately upgrade the injectors?
edonald849
02-22-2009 04:44 PM
jmccart
11-25-2007 11:38 AM
roadranger
10-22-2007 08:11 PM
cincydiesel
06-23-2007 08:39 PM
Trusty Steed
02-24-2004 07:11 AM
Quick Reply: What is a good towing Turbo
