What to get next, cp3 or R700 upgrade
I have been going back and forth for awhile on which thing to get next. I am running the Revo on the smarty and it runs fine. I dynoed 560 with the DDP 50's and have since changed to the 90's. Pressure looks ok as long as I don't run the TNT sw. I know I am about max on the Tow Twins. What do I get. I got the money and want to spend before it burns through my pocket.
Like you said your maxed or close to maxed with the tow twins, even with the new bigger sticks. You can mod the CP3 or go with duals CP3's, but your HP will be the same with the tow twins. If you just go with the R700 you will be limited to around 600hp with your current CP3. I would do both so you can run the TNT without draining the rail. I guess if I had to choose one I would do the R700 at least they is a few more ponies there.
The 57 and 66 are both built off the S300 design.I know your top turbo is not the exact same size as the bottom.The super b is the top so its a 57.What size is the bottom turbo?
highrpms
07-03-2008 11:47 AM
DUKCALN
04-10-2008 01:58 PM
kantdrive55
23
12-15-2007 05:00 PM
kantdrive55
19
10-26-2007 12:15 AM
