What does the Quadzilla Rail Pressure Gauge read?
I got one on the way. I wanted it for Rail and Lift pump pressure. But when looking at them on the net it says boost and egt and oil as well. Do they read all that? or just rail and lift pressures?
Rail and lift only This is the website.......http://www.quadzillapower.com/produc...ure_gauge.html
I'm pretty sure you can use the lift pump pressure sensor for boost or oil pressure if you want. I think it's just a general electric pressure sensor.
The RP gauge itself will only read two parameters. RP and pressure (where ever the pressure sensor is located). No EGT's.
D45
15
07-08-2008 09:45 PM
5.9Excursion
03-13-2008 10:56 AM
mopardamo
02-10-2008 07:04 PM
rattlbox
09-04-2007 02:20 PM
