what to do with stock pump after ad 100 install
what should i do with my stock pump/ filter housing after installing my ad 100? will it hurt anything to leave it in place? should i just remove it all to free up some space under the hood?
you can leave it in place or buy a GDP filter eliminator bracket and take it off...
http://www.glacierdieselpower.com/pr...x?pf_id=0306FE
Location: In Oroville, Ca., same house for past 46 yrs!
eliminator plate
You can make one like I did.
https://www.dieseltruckresource.com/...d.php?t=191118
post no. #5
read the pdf.
post no. #5
read the pdf.
post no. #5
read the pdf.
post no. #5
read the pdf.
Denny nice job on that bracket!! thats pimp
thanks
I wanted to run my twin holleys but I didn't have any other filter except the stock one which I love. It also has the water drain and indicator and the heater too which I wanted to keep.
I had to fool the ECM but as of yet I haven't had a single code pop because of the adapter and signal fix which is in that pdf article.
Thanks a bunch for the vote of confidence.
I can't always afford the top shelf stuff but it'll run like one.
db
db
89dieselkong
11-17-2011 05:51 PM
6 2 Carl
11-27-2010 09:55 AM
53 willys
38
11-06-2008 11:18 AM
Tiara3100
12-21-2007 01:42 PM
