what to do next? I want more Power
keep the juice for the monitor and get a smarty?
I have a 04.5 ctd and i have a edge juice (w/ Hot unlock) with attitude,Air intake And a fass fuel system with straight pipe and will soon have a south bend clutch. my truck is lifted with 37" toyo m/ts and I want to make it faster any recomendations?
Well, a Ts Mp-8 is the pressure box that most people are stacking or the edge EZ. That's what I intend to do after I get the Hot download someday. After that, I suppose injectors and a bigger turbo would be in order.
I have a similar setup. I have found that the Quadzilla Race fuel only tunes and the Diablo Predator go along very nicely with the Juice. Definitly add some pressure once your clutch is upgraded. The Predator has some 200HP fuel only tunes that are just awesome with the juice. Make sure you have rail and fuel pressure gauges though
Yeah, that's what we're saying about the Mp-8, EZ, Quad, etc.... They all are pressure boxes that are known to stack well eith the juice/attitude and add h.p.
Whatever you decide to go with, ensure it does minimal to zero timing. Timing/duration is what the Juice does for the 04.5. For a cheap but noticeable pressure upgrade, looke at the Diablo power puck. I had one for quite sometime and it was a very nice "moderate" stack with the Juice. YOU WILL NOTICE IT! Plus if you outgrow it you can get a good price on EBAY for it.
is that DIY cp3 mod worth doing? And will a pressure box make my egts run hotter? Cause i already have a egt problem. my truck will hit 1450 easily. what can i do to keep the egts down?
44's n 454
I think your better off stacking. The attitude still needs the Juice to work, even if you have it set to stock for gauges. I'm telling you, add pressure and the Juice really wakes up! I don't know about you, but I do like the on the fly adjustability that a module provides. I once went up in the mountains here and forgot I had the 200Hp fuel only tune loaded from my Predator. Let's just say I made alot of enemies behind me! Now i only use the Predator when I know I'll just be racing around!
