what color wire for switched power on an 05'
anybody know what color wire under the dash i can tap into for a switched ignition power source for my gauges? i was looking for the pink wire w/ yellow trace on the 100 pin harness by the ebrake but i think that was for 06's? what color are the cig lighter power wires? going to dig out my test light but thought i would ask before i go poking all those wires! thanks RB
if you go to www.the12volt.com you can find all sorts of wiring info..
It is a pink wire with yellow tracer that your looking for. I actually found 2 of them when I was hooking up my guage. There is a large one in the big bundle of wires you mentioned, I used one I found running up the a pillar on the drivers side (noticed it came into a connector and didn't continue out the other side) this was perfect for me I had the a pillar off to replace it anyways.
Scotty
07-22-2012 08:31 PM
TPilaske
16
11-22-2002 08:15 PM
