What can I use to plug Exhaust Manifold EGT probe hole?
So, I traded in my 2004.5 on my 2006 Mega Cab. I will have to bring my truck in by next wednesday (dealership is giving me time to take off what I want from it). I will be taking my Quadzilla Commander guages off. That means there will be a hole in the exhaust manifold from where the egt guage was installed. My question is what should I use to plug it? Anyone got any suggestions?
Will the brass be affected by the heat of the exhuast stream ? (Sorry, I'm not very knowledgeable about metals). I want to make sure I plug it with a safe metal that won't melt/crack, etc. The dealership gave me a great deal on my Mega Cab and I want to make sure that whoever eventually buys my truck that I traded in, gets something that is going to be safe.
Most brass plugs aren't pure, they are an alloy of some sort. I wouldn't use one as there is a chance it could melt. Just get a good old fashioned 1/8 npt plug, black or galvanized pipe.
i'd pop for a machined steel pipe plug with a hex head.. easiest to remove/apply after many heat cycles. cheap cast iron plugs with a square head can have the head crumble when removed rounding it off.. just some hi-temp antiseize on the threads and don't overtighten it...
yeah brass is the answer.. but like what dzilla said,, is a good idea, gives you a chance to put a new probe on,, they do wear out after time
Kevin
Kevin
SilverRam3500
02-10-2008 11:01 AM
Cummins600
10-03-2004 11:13 PM
