What BOOST PSI should you see when u mash on it?
Old 02-03-2008, 05:45 PM
sallyman1's Avatar
When u mash on pedal (unloaded) what boost psi should you see? The most i can see on my 2004.5 with edge juice on level 1 is 25 psi or so. Even on level 3 it dont get any higher. is this normal?
Old 02-03-2008, 05:51 PM
06RAM2500's Avatar
I get around 15-20. But it really blasts after the T/Q locks up. Thats when She'll hit 30+.
Old 02-03-2008, 05:52 PM
06CTDforAU's Avatar
See your other thread.
Old 02-03-2008, 06:17 PM
Big Smoky's Avatar
Do you have a boost elbow? If not, get one....it'll help.
Old 02-03-2008, 06:23 PM
06CTDforAU's Avatar
He has an 04.5 so he has an electronic wastegaste correct?
Old 02-03-2008, 06:26 PM
Big Smoky's Avatar
You're right. Sorry, I didn't even notice that.
Old 02-03-2008, 06:27 PM
Billm2004's Avatar
04.5 has the electronic wastegate, you will need a boost fooler to see higher than 25 or so. with the fooler i saw 45 on my stock turbo
Old 02-03-2008, 06:28 PM
marc03's Avatar
with my juice on lvl 3 at wot for long periods I can hit 40+ psi no problem.
Old 02-03-2008, 06:32 PM
06CTDforAU's Avatar
I wasn't completely for sure, that's why I asked. At least you were trying to help.
That's what I was thinking. With mine on any level I hit over 40 easily every day.
Old 02-03-2008, 06:50 PM
blh1972's Avatar
40+ psi daily
That's why your egt's are so high.
Old 02-03-2008, 07:24 PM
Tiara3100's Avatar
When I mash it, I see a spike to about 32psi, and then it drops back to 28psi. Exhuast temp goes to 1350 . Boost fooler comming soon....
Old 02-03-2008, 07:28 PM
sallyman1's Avatar
how long do u mash on it till it hits 35-40? I only mash it for like 5-10 seconds and the boost only gets to like 27 psi (on the attitude monitor) and then backs down to 23-24 ish, until i let off. then it goes down to like 10.
Old 02-03-2008, 07:30 PM
06CTDforAU's Avatar
About a second or two (at the most) the boost is over 40. Doesn't take long at all. That's why I think something is wrong with your turbo.
Old 02-03-2008, 07:31 PM
tburks's Avatar
I had the same problem with my 2005 and it was the Edge Juice with Attitude was bad. I called Edge and they had me send the unit in and three days later I had a new unit and I now I can hit 40+ all day.
Old 02-03-2008, 08:45 PM
chy46's Avatar
boost
I run the preditor , Hit 38psi no problem at all , rundown the road with 14-18 bls average. 04.5 cummins
Quick Reply: What BOOST PSI should you see when u mash on it?
