What boost gauge
What boost gauge
Before I order gauges what boost gauge, will I need the 60# , I guess if I got it I'd have it. Also I am getting the tranny line for the sending unit. I know there is probably past posts on this subject so thanks for your time again.
Yes you need at the 60psi boost gauge. Stock will hit 32-34psi and settle in the 28-30psi range on WOT. Most performance mods will raise the max boost psi into the 40+ range. Aftermarket turbo and performance will raise it even more.
with the few mods i have i have hit 40 lbs several times. i have a 100 lb gauge but that was a screw up from the place i ordered it from. i was supposed to have had a 60.
Performance & Accessories Bully Dog Triple Dog 40500 w/Crazy Larry, Outlook, boost gauge, pillar mount, boost f
gpshemi
3rd Gen All Products
0
07-19-2015 06:25 PM
Tank_66
02-28-2008 08:34 PM
turbomike
12-03-2007 09:31 PM
CRXsi
03-31-2006 07:56 AM
