What is The biggest tire I can put on a Stock 04 2500?
I have called around to multiple tire stores and they have told me 265s are the biggest tire I can put on I call BS. I was told 305's will fit is this true? and if so arent 305's just shy of 33's and if so can I run 33's? need a reply yesterday under the gun for new tires.
285's and 295's are just shy of 33" - the 295's are wider. 305's might be just over - not sure. I'm running the 285's on stock rims without issue. They are 32.8" in diameter new.
i am running 315/70/17 mickey thompson atz's on my stock 06 truck. They will rub the control arm if you turn them to full lock but not bad enough to worry about.
I run a 295/70/17 Nitto Terra Grappler & love 'em. I'm on my 2nd set. No suspension mods at all.
See pics here: https://www.dieseltruckresource.com/...er.php?u=41652
Ive personally run 315 BFG's with a very minor rub on control arm on a stock truck, my friend ran 35" Toyo MT's on his stock 06 with minimal rub, and Ive seen pics of a guy put 37's on his STOCK truck with the same rub he got from 35's. The 35's still afford some room to play in the dirt, but the 37's will sideline you at the Mall.
All stock wheels, BTW.
305/70/17 is 33.81 tall 12" wide......315/70/17 is 34.36 tall and 12.4 wide. You should be able to fit 33's no prob. i have a 2wd and i fit 33's with no rub. So i dont see why you cant run 35's
jesussaves
02-20-2009 06:12 AM
JG FENCING
12-30-2007 06:52 PM
RedRam410
10-27-2006 03:25 PM
snowmanx
09-24-2006 06:24 PM
xj2extreme
02-26-2003 06:17 PM
