What is the best programmer for towing?
I am new to the deisel forum. i have an 06 dodge 3500 dually that i use every day for towing. i tow anywhere from 10 - 25,000 lbs. i now have
50,xxx miles on the truck and have decided i need a programmer and some more mods to improve power. i haul over some extreme grades and need more power. just dont know what to go with. i would appreciate any help i can get.
06 dodge dually 3500, quadcab, 3.73 gears, 6 speed manual with jacobs exhaust brake
I would start with cold air intake and a free flowing exaust. Then either a box of your choice or a programer. If you dont want to put in guages you could go with a Edge juice wit att. or a quad commander, or bully dog has the out look monitor. Check the classifieds as there is always some great deals. Guages of some sort are needed with any power adder especially towing heavy loads.
Brian
Brian
To add to that list I would say the quadzilla boost fooler. It really helps keep the egts down by allowing your turbo to create more boost before dumping it. With a programmer I can now get over 40lbs of boost and egts will only peak at 1500 degrees as with out the fooler and a programmer it burys th needle which I think is 1600 +. And for only 80 bucks is a really nice easy piece to put on. Just plugs in under the hood.
thanks for the input
thanks for the input. i was thinking about the edge with juice or maybe the smarty. as for the air intake i saw a bully dog on the classifieds for $100. price sounds right, but is it a good air intake. how much performance does the exhaust give, cuz it doesnt seem right scraping a perfectly good exhaust. maybe just take off the cat and muffler? I appreciate the help, please keep it comming.
It prevents the wastegate on the turbo from opening by tricking the truck into thinking the boost psi is lower than it really is. In stock form the wastegate opens around 30psi so that is the most boost you would see. It may go to 40 or so with a boost fooler.
Oh - forgot your exhaust question. I agree - you already have a perfectly good full 4" stainless exhaust from the factory. I would ditch just the muffler first and see how you like it. If you lose both it will probably drone bad especially if your towing all the time. Or you could get rid of the muffler and cat and replace with a free flowing muffler. Either way no need toi shell out cash for a full exhaust system. And any intake system is an improvement over stock. AFE probably most popular - also most expensive. I like my AEM. Good luck.
TST R49. Get the version with gauges built into the unit. Adjust boost, Rail pressure, Defuel on temp, adjustable on the fly. You would not be able to use all of the settings with stock turbo and fuel but at least the box would be there if/when you want to add more. I have had one for a couple of years and it has been great. It also helped with my mileage, when you keep your foot out of the throttle.
http://www.tstproducts.com/index.asp...ROD&ProdID=135
Jeff
Jeff
The juice with attitude is a great add-on. I regularly tow our 13,500 lb. fifth wheel and love the features and the guages. You can set the fueling paprameters (i.e. - defueling, turbo timer, etc.) to make sure your on the safe side when towing. It is very smooth power -- better than most other performance boxes. In the future you can get the hot unlock and have more power. I've found adding an EZ for pressure adds alot of bottom end and generally drive with the EZ on the lowest setting, the juice w/attitude on zero and have increased my mileage. Both can be found second hand at very reasonable prices.
looks like the edge w/ juice is for me
from what you guys are telling me, im gonna go with the edge w/ juice. sounds to me like its the most versatile for me. im also thinking about the afe stage 2 air intake. what would be a good free flowing muffler to replace the stock.
____________________________________
2006 quad 3500 dually, 4x4, 6 speed manual, jacobs exhuast brake, b and w turn over ball, line x bedliner
