Weird Vibration
Weird Vibration
Like the title says I get a weird vibration or shudder after my tranny shifts into OD under heavy throttle. It only happens in OD and under heavy throttle and not just at shifts but anytime I goose it. I replaced my Uj oints already but its still there. Anyone have a clue as to what this could be?
1 piece driveshaft or 2 piece, ive heard of the center "bearing" going bad, the name escapes me now but im just throwin that out there. I have a one piece and i get a shudder at about 69mph to 72-73 mph 1800-2100 rpm looked it up here and it talks about driveshaft "flex or twist"
Location: Used to be missoula, montana: Now in Sonoma County California
Its called torque convertor shudder, basically the clutch is "chattering" upon engagement. Two fixes....replace tq convertor (good time for upgrade), or raise the line pressure inturn raising clutch apply pressures(not a very good long term option)
I had a Truck that did this same thing the problem i was having was caused by to much flex on the rear end i installed torque rods from rear axel housing to frame to keep the rear end from torquing up and down. I only had this problem when pulling a trailer that was heavely loaded and under heavy throttle, it could be torque converter shutter as will but i had mine replaced with an ats converter and still had the problem
2004 2500HD smarty k&n intake, jammer 100hp nozzels, ats manifold, ats trany kit and converter.
Oh man this is going to be expensive! The truck only has 63,000 on the OD would an aftermarket TC and VB do me some good. Or should I just wait for full tranny. Any opinions are appreciated.
probaly not the case here but ill throw it out there,i just had my frt d shaft grenede on me,the ball in the middle of the 2 ujoints in the constant velocity joint grenaded,before it did it vibrated at high speed,just a thought
Common
04-09-2008 10:25 PM
