weird camander readings after update???
i just updated my camander to work with my x2,before the update with the camander set to 03-04 5.9 my boost would show 6-8 cruising and very easily go to 15 shifting thru the gears,now it only shows 2 while cruising and goes to 6-8 while shifting,also the coolant temp is doing somthing weird,it used to show 188-190 while cruising{i bought a 190 tstat last year}when i set the camander to 03-04 now it shows over 200 while its the same on the truck gauge,when i change the camander to 04.5-07 it shows the 188-190 it used too,rail pres seems the same,fuel pres was 20 before the update and now its 10,im sure i have the 40psi sender,but with the old camander version was it defaulted to the 100psi sender?if i pput it to 100psi sender it goes back to 20.anyone else have weird readings after the update??
i checked quads page and theres only one file,the new one,i wonder if there was a way to save the old file?is anyone else getting diferent readings after the update?i really hate to go to all the work of checking the fuel pres with a manual gauge and checking the boost with a manual gauge.im kinda worried about the accuracy of this thing if the readings change so much
duallydave
04-09-2008 09:45 AM
duallydave
04-03-2008 06:51 PM
duallydave
03-31-2008 12:47 PM
duallydave
03-25-2008 03:18 PM
turbotowrig
12-22-2007 07:15 AM
