which water meth system to get??
Having the tank underhood really heats up the liquid. There's lots of room in/under the bed and it's cake to run the lines.
madhat's monkey boy...
I didnt really think about the under hood temps, I was more concerned about it freezing in the winter. How low of an amount of methanol do you need to add to keep it from freezing to say 10*F? That is about as cold as I have seen it here. I could mount a big tank to the front of the bed since it is dead space from the stacks.
I would definitely use that wasted space for the tank.
The devils own kit taps into the windsheild washer tank. Holds a gallon and the little light on the dash comes on when you need to fill. Be carefull of fluids with -20 or below. They do not use methanol for the antifreeze agent. The name escapes me but the type of alcohol in those can damage your engine.
Treangen
10-02-2008 03:11 PM
Treangen
05-06-2007 07:51 PM
