Water Meth Questions
What size of injector/nozzle is everyone using? The range coolingmist sells ranges from .75 to 12 gallons per hour. Also does everyone use two nozzles? How far apart do you put the nozzles on the intake horn and does it matter where the boost port is located in relation to the nozzles? I need some extra help with cooling. Thanks, Jay
I was running a 12gph nozzle along with a 16gph nozzle in my 1st gen and that was only at 300-400hp. I'm sure a CR at 400-500hp would need even more than that.
For anyone buying/using a Snow kit, make sure you have a check valve or solenoid somewhere in the system to prevent siphoning water into the engine when turned off. It seems Snow likes to rely on their pumps to prevent siphoning. That might not work 100% of the time and a check valve/solenoid also keeps the system primed at the nozzle so you get instant response with no dripping at the start or end of the injection cycle.
DIESELWRKS
10-03-2010 03:35 AM
DENVERDODGE04
02-12-2009 08:19 PM
jdpiii
06-19-2008 07:34 AM
