Walbro 392 fuel pressure problems
Administrator/Jarhead
So...
I had the 392 with the big line kit hooked up in line with the stock LP and was seeing a solid 30 PSI at idle, and 22-23 at WOT. The stock LP dies, and I get the adapter from GDP. Now I have a solid 20, 15 at WOT. All of a sudden, after a hard pull, my pressure is around 5-10, tries to come up to 15 a few times. Get home, shut the truck off, the next day, she reads a shaky 20 PSI, going from 20-18 at idle, and pressure dropps hard(5-7, 0 one time) when I get on it. I changed out the filters, (they were not even a month old), and nothing changes, except the recovery time after WOT, which is good like usual.
??? Time for a new pump, or could it be the check valve? What about the pressure, who else is running the same setup?
TIA!!!
mad
TIA!!!
mad
So...
TIA!!!
mad
TIA!!!
mad
things that can cause low feed pressure.
-cavitation
-bad filters
-plugged by-pass valve
-bad spring in by-pass valve
-pump cannot keep up to injection demand
The bypass on the simflo regulator is preset at 15 to 20 PSI according to Vulcan. I am assuming GDP uses the same regulator. When you were using the Walbro as a pusher pump through the canister pump the canister added pressure. Remember the canister pump is located pass the regulator. When you get 20 PSI at idle with just the Walbro sounds right.
The Walbro is capable of higher pressure but you will need a different regulator.Swagelok has an adjustable regulator from 3psi to 50psi.
http://www.swagelok.com/search/find_...2-3&PG=0&RPR=5
Madhat, how are you reading fuel pressure??? If you're running an isolator, I'd bet that's the problem.
btw- I made 617hp and my pressure never moved from 20psi. Never moves at all... course I have a different setup but same Walbro 392...
im having the same problems madhat. I started a thread the other day on the same thing. same fuel pressure as what you have and everything. mine hasnt got any better either. I dont know if the cold weather is hurting these pumps or what? I had mine put on in the winter im pretty sure and its always done good until now.
if you were talking to me, I run an isolater with the dipricol fuel pressure gauge I have. the thread I started about mine a guy posted his antifreeze was low in his and he filled it back up. im going to try that also because I did loose some antifreeze not to long ago
I run the same setup as Trik396, except i run at 38psi at the injection pump. Even at WOT I can only pull it down to 37psi for a split second. And that's on an inline jegs wet gauge and the Commander. You shold tell us if you have a draw straw.
Anyway be careful running over 30psi because some guys reported popping the cap off of the stock fuel filter canister. I've got the same Jegs guage on my bypass regulator...
I had the same pressure fluctuations on my set-up lat year.
Take the regulator apart and look at the plunger. On mine the plunger was machined and had some burrs that folded over. These burrs caused the plunger to "hang up" in the bore. I took the plunger and dressed up the machining with an exacto knife and then cleaned with brake-cleaner. All is well now!
No Isolator, I get the fp reading off the adapter that replaced the stock LP on the canister, and I changed the filter again last night.
I have the vulcan big line kit in the tank. I have the pump mounted on the frame by the xfer case.
I was looking at the spring kit last night for my pump...
It's just the sudden change that bothers me... I'm thinkin that it's the bypass valve just takin a vacation...
