Volumizer II Installed!!
Just installed the Volumizer in my 600 It has 3 settings, 60-100 and stock hp. This box connects to the map sensor-rail pressure sensor- cam sensor-crank sensor. I could tell that the timing was advanced in both the 60 and 100 hp settings. Day and Night difference from the stock to the 60 hp by just the sound of the motor. I will check milege this week and post back . My overhead milege went up Quite a bit so I dont think it is correct but if it is correct WOW!
Chubby,
Mine is a 555 but after almost 7,000 miles in a little over 4 months of use, I have had zero problems and zero codes . See my gallery for dyno results.
The Boss Hog
(Also zero mileage gain . . . . . . )
The Boss Hog
The Boss Hog
13
08-09-2004 06:10 PM
bhoeffner
08-04-2004 10:37 PM
The Boss Hog
02-27-2004 03:08 AM
