Vibration Damper
Vibration Damper
I was checking stuff out after I made some mods to my airbox ('04.5 and up size hole now and a gap to hopefully stop snowingestion.) I noticed some dried mud in my harmonic dampener. I also noticed that the rubber was starting to come out of the damper in a couple spots and at the end of the string of rubber was visible. What should I do? Get a fluidampr? Is it ok? I know they don't last forever. Should I find a low milage stocker for cheap and use it? I will try and take some pictures and upload them.
It's not a huge difference no. I needed it for one with tnt-r tune to rev higher, and I was towed home twice with the oem's so I bit' the bullet. I was actually lucky and found some that were made for bullydog that were discontinued, same as fluidampr with bd stickers. Got it for 200.
Not sure about the Cummins b series but I know for an absolute fact that a faulty balancer will cause the HPOP gear to loosen up and move on the shaft causing a instant shut down and no start. In some cases it will back off completely and ingest into the gear train and do some serious damage, like the one I just fixed to the tune of $3k.
That's been over a year ago so yeah. They were in a group buy from CPP. I will ask him if he would be able to do that again but I doubt they would be that price since those were discontinued.
dodgedsl03
01-18-2007 10:08 PM
