Van Aaken C5 - 3 in 1 Module Coming Out Soon
Sorry if this is common knowledge, but I just spoke with Van Aaken and they are currently working on a C5 (as called by the developement dept.) that does timing, duration AND pressure.
Just a head's up for those of you trying to decide what to get. It should be out very soon. No turbo timer feature, though.
I'm running one of the C5 Beta boxes and all I can say is that so far I really like it. It fuels hard down low and the power is real smooth throughout the whole powerband. The tester I have is only adjustable between three preset tunes at this time Stock/50%/100%. The high setting is probably equal to around a 150hp box. The product that is being released will be fully adjustable for rail pressure, timing and duration. I hope to get to a dyno some time next week to get some #'s.
94ttss, I've emailed VA about this but they haven't responded yet. Do you know if the timing will be adjustable from no timing to 15-18degrees in one degree increments?
Not sure on the release date, probably early summer.
I'm told all three parameters will be fully adjustable. I will find out wether it will be a min/max range or individual degrees of timing.
the box i have is great on power, and the adjustment is superb, all digital monitoring and adjustment in RP, timing, and duration, and several others. release will be around may.
CTD06
28
07-10-2007 06:49 PM
xp8103
06-30-2006 10:06 PM
high country
04-15-2005 06:48 PM
Copenhagenjunkie
05-19-2003 08:04 AM
