Valve Spring Pressure Question
Old 07-14-2008 | 05:53 PM
lcaad1249's Avatar
How much pressure is too much for valve springs? I know the stock are around 60#, F1's are around 90#, the Hammilton's are 110#, and then there's some higher pressure like 140# pressure springs. Obviously I don't need the 140# springs, but is 110#'s too much to have on a daily driver I want to get a lot of miles on?
Old 07-14-2008 | 06:18 PM
Billy Ram's Avatar
If you don't plan on going much over 4K rpms you shouldn't have a need for the #140 springs. The #110 springs are rated for 4.5K rpms @ #80 boost.
Old 07-14-2008 | 06:20 PM
wap's Avatar
wap
Arent the F1s 110 lbs too?
Old 07-14-2008 | 06:34 PM
homewrecker's Avatar
Stock is left,Sportsmans are right
Seat Pressure 80 lbs 93 lbs
.100" lift 100 lbs 125 lbs
.200" lift 120 lbs 157 lbs
.300" lift 145 lbs 193 lbs
.325" lift 150 lbs 200 lbs Stock 24V Intake lift at the Valve
.395" lift 175 lbs 225 lbs Stock 24V Exhaust lift at the Valve
.400" lift 179 lbs 230 lbs
.450" lift COIL BIND 245 lbs
.500" lift COIL BIND 255 lbs
.550" lift COIL BIND 265 lbs
.568" lift COIL BIND 270 lbs
Old 07-14-2008 | 11:12 PM
metal_miner's Avatar
Here's some interesting reading:
https://www.dieseltruckresource.com/...t=valve+spring
I need to go re-visit my college engineering mechanics text books to understand Hohn's posts!
Rpainter
05-25-2008 05:52 PM
noscabs
01-28-2008 09:59 PM
West Coast
12-01-2007 03:33 PM
scottmn1
01-11-2007 05:22 PM
justinp20012500
12-14-2004 09:45 AM
