Updating smarty
#46
THere is
appearance and themes??
Network and internet connections
add or remove?? Tried that no worky...
Sounds
Performance
Printers
Accounts
Date time
Access
security??
This is all on xp??? Man I suck at this!!! Sorry and thank for the help fellas!!!
#48
Not sure why you do not see the "System" icon on the "Control Panel" window. That is a little strange on XP. Could be related to local admin permissions I guess. But there is another way to get to the "Device Manager" window.
On you desktop you should have a "My Computer" icon. Right click on this icon. On the menu box that opens, click(left button) on the "Properties" option on the bottom. This will bring up the "System Properties" window and menu. Click on the "Hardware" tab. Then click on the "Device Manager" button. This will bring up the "Device Manager" window. Right click in the window anywhere; this will ensure you have a menu option for "Scan for hardware changes" option. Make sure the Smarty is plugged in and powered up. Click the "Scan for hardware changes" and then follow the instructions for the USB device install from the Mads website.
Let me know if you can get to this point and maybe I can help further.
#50
Hello , To be able to update your smarty ecm tuner. Please follow these guidelines.
Start by right clicking on your desktop to create a new folder. Rename the new folder smarty.
You will need to download the driver to the smarty folder. Save the driver to the smarty folder http://www.madselectronics.com/downl...DM_2.00.00.zip
You will need the smarty usb.exe This program allows you to update the smarty. Save this to the smart folder http://www.madselectronics.com/downl.../SmartyUSB.exe
The driver and the software programs need to be extracted into the smarty folder using THIS extraction tool. http://prdownloads.sourceforge.net/s...2.exe?download
Here are the directions for installing the driver http://www.madselectronics.com/downl...stallation.pdf
Once you have the driver installed you can use the smarty usb.exe program to update the smarty software. Click on the smarty icon. Press run. You will now see a seen button. Before you hit the send button you need to load a program into the smarty usb.exe. Click on file. Open , look in the smarty folder to find the smte file to load into your smarty.
Load the file and press run. It will take about 40 minutes to update your smarty.
Thanks
Bob
Thanks
Bob
#51
#53
Thanks
Bob
Thanks
Bob
#55
#58
You need to change the "c:dxx22" thingy to the actual directory on your machine where you unzipped the driver software. It will be somthing like "c:\smartydownloads\" or maybe "c:\smartydownloads\dxx22" depending on where the file was unzipped to.
#59
Yes what Bob said, it needs to be unzipped. He can probably help better than me, but I have helped lots of users with this type of frustration, both Smarty and other windows junk.
#60
right click on the file and "extract here
