Unlucky SOB needs another set of Injectors
Old 09-11-2006, 11:03 AM
abc4yew's Avatar
HaHaHa, under control....they found the paperwork but they still haven't matched the paperwork to the box.....I should check on EBAY....they are probably already listed....if they don't get enough on EBAY they'll probably send them to DonM. Thanks lmills, I hope I don't have to take you up on the offer. ks
Old 09-11-2006, 05:41 PM
wap
wap's Avatar
So you got everthing under contol on Monday? Like I said?
Old 09-11-2006, 05:56 PM
abc4yew's Avatar
Nope, They told me they would call me back when they located my injectors....no call.....no update on the tracking #....They did scan the paperwork again...but when I called back they had misplaced the paperwork I had faxed... so I faxed it again...still fricked.... I'm optimistic thanks to you guys so I'll check after 11:00 which seems to be the Louisville scan cutoff time. ks
Old 09-11-2006, 07:47 PM
wap
wap's Avatar
I misread, it said they found the paper work and I thought it said they found the box.
Oh well there is all ways Tuesday.
Old 09-11-2006, 10:18 PM
abc4yew's Avatar
With my luck, I always like to have at least one other backup to fill the gap for the inevitable dump of dung. Still looking for a set of injectors that work just in case the paperwork never gets attached to the actual box with the actual 6 injectors in it. ks
Old 09-12-2006, 06:39 AM
lmills's Avatar
if you can get me a set back from your storage, I've got you covered for a set of bodies
Old 09-12-2006, 10:33 AM
abc4yew's Avatar
So far so good, They just called me and they found the box and the paperwork was reattached to the box so it could enter customs clearing, it cleared customs and it's hopefully on its way to F1 Diesel this afternoon. Gotta love that UPS overweek delivery. And yes I'm gonna get my money back for shipping eventually as the outside of customs problems still ate up 3 days of overnight time. ks
Old 09-12-2006, 10:49 AM
lmills's Avatar
sounds good!
Old 09-12-2006, 05:21 PM
wap
wap's Avatar
Glad to hear they finally found your package.
Old 09-12-2006, 07:26 PM
abc4yew's Avatar
Guys, I just can't wait till DonM tells me they've arrived tomorrow...and when he gives me the tracking number for the return...just found another major snafu when I started to work on the block in anticipation....I'll report later... When you have a big bucket life will fill it to the rim with crap. ks
Old 09-13-2006, 08:41 PM
abc4yew's Avatar
Well, Not quite before noon delivery but its better than lost. I guess it will be another weekend without this truck. ks
Statuselivered
Delivered on: 13/09/2006
15:37
Old 09-18-2006, 02:35 PM
RowJ's Avatar
Originally Posted by Thenewguy
It has to be GM and Ford behind it.
I knew it couldn't be Ford....cause they own Cummins, Right?
RJ
Old 09-18-2006, 08:29 PM
underwoodtransp's Avatar
ok so do you have to send in your injectors to every place to get worked on or can you just buy a full set of reman worked over sticks??? I know at least one of mine is wigged out so I don't want to spend the money to buy a stocker to have another one go out. I would rather buy a full set of new or reman ones and send mine in for cores and see what I can get back??? What do You all think???
Old 09-18-2006, 09:34 PM
WUnderwood's Avatar
it is my understanding that if you want to do more than tips, you have to send them your injectors because there arent that many cores available.
Old 09-18-2006, 09:57 PM
abc4yew's Avatar
The last time I did the injectors, I got a set of remans from II and then sent mine back. I figured I had lots on the go what would I do with a perfectly good set of stock injectors. At the time II had lots of good remans....now they have over 900 injectors that need repairs and no remans on the shelf. Soooo in most cases you need to send your injectors in and be down for that time. If you find a set of good spare injectors...put them in a safe spot as it seems they are worth almost as much as gold these days. At my dealership $585 per injector and $200 per hellfire nozzle makes usd$4710 plus $440 for air shipping and insurance = 9 pounds@ $572 a pound. The only thing more expensive per pound that is harder to get a hold of is fake *****. ks
Quick Reply: Unlucky SOB needs another set of Injectors
