Ultimate's Rock Crusher Transmission
Old 03-28-2008, 09:13 PM
Snapoff's Avatar
Hi All!
Though I'd give an update on my new Ultimate Transmission.
While the case is not much to look at the internals of this thing are absolutely huge and are darn near bullet proof.
Take the 1.5 inch output shaft for instance. It is the same size as the axle shafts in the rear diff.
Check it out!
Below are pictures of the stock transfer case input and the "Opie/Ultimate" piece.
The puny stocker...
And The real deal!
What I can't show you is how lightning fast this thing shifts yet it isn't harsh or doesn't bark the tires (unless I want to). The Ultimate never hesitates or hunts between gears and is extremely positive.
As soon as you start adding big power to a Dodge you begin to realize that the factory has first and second gear way too close together....Not to worry as Opie and Dave have got the shift pattern dialed!
The trans shifts from first to second and unless you really pay attention you wont notice that the trans has shifted again and you are in third....This uses the torque of the Cummins to max advantage.
Acceleration is nothing short of spectacular and I wish that I had run the truck down the track before the Ultimate so I could compare the ET's.....Then again I broke every time I tried to launch the truck hard! I guarantee an improvement over a standard shift pattern....Stay tuned for track times.
I also can't show you the other numerous unique and one off parts that are inside...I can tell you Opie runs some fairly sick line pressure and that you won't find a transmission with more clutch pack pressure!
While it's street manors are a bit aggressive for guys under 700hp... and its not for everyone..... I though you horsepower freaks would be interested.
Old 03-28-2008, 09:51 PM
Sandaholic's Avatar
I'm pretty sure I'll never own one, but I'd still like to learn more about this trans. Is it still the same case as the 48re or is this a completely different tranny?
Old 03-28-2008, 09:58 PM
omaharam's Avatar
So basically it's the price of a 2002 Toyota.
Old 03-28-2008, 10:04 PM
madhat's monkey boy...
matego's Avatar
If you could get three fingers in there, I would run the other way.
Old 03-29-2008, 02:50 AM
Snapoff's Avatar
Ultimate uses the factory case...thought they do blueprint it!
As far as price goes something high quality like a fully built Goerend or its sort with all of the billet goodies and a best quality converter will cost just short of 8000 bucks.
The Ultimate is competitive price wise (believe it or not) with any of the big names....Yet in terms of pure componentry and brute strength there is no comparison.
You can not buy the strength of the Ultimate anywhere but at Ultimate...At any price!
I have to add that you will not find a nicer guy than Opie.
He posts here and if you need some more technical answeres he's you guy!
Old 03-29-2008, 09:56 AM
XLR8R's Avatar
ROFL! Funniest thing I've read today!
Old 03-29-2008, 09:04 PM
tristan21's Avatar
......................or step outta the way so a man can take care of buisness.
Just couldnt resist could ya.
Old 03-29-2008, 10:41 PM
HRT Offroad's Avatar
How do I get ahold of Ultimate...and where are they located?
Old 03-31-2008, 10:03 AM
cquestad's Avatar
Boise Idaho!
Love mine...love it!
Old 03-31-2008, 11:28 PM
Snapoff's Avatar
We are going to have a spare built.....Perhaps we can work something out....
Give me a pm if your interested
Old 04-01-2008, 12:37 PM
5.9Excursion's Avatar
I assume the custom transfer case input shaft (which is bigger than stock) was required to fit the larger output shaft from the tranny?
Old 04-01-2008, 12:53 PM
tristan21's Avatar
I was curious who is makin any 6sp parts outta billet? anybody know.
Old 04-01-2008, 05:54 PM
jalewis's Avatar
Exactly...phone number? Website?
Old 04-01-2008, 05:57 PM
cquestad's Avatar
email me...I don't want to get in trouble for "advertising"...
cquestad@ssproducts.com
Old 04-01-2008, 06:39 PM
Snapoff's Avatar
Yup...Not to worry though....It's readily available in an err.....inexpensive format!
Opie can fill you in....
For those that want to know more about Ultimate PM OPIE.....Or you can PM me for contact information.
Quick Reply: Ultimate's Rock Crusher Transmission
