with twins what chip/injectors.......???
with ats 3000 and 5000 turbos combo on my truck what size injectors and what chip would do better than the edge juice with attitude ???? but still be safe to pull my 20000 pound dozer without getting hot??
Smarty Sr. with a TST R49, and HOLD ON!!!! I see that is a 2005, do you have the plastic end tanks on your inner cooler? water meth might be a good route also with hualing your dozer... I would run Flux 1.5 injectors...
Smarty and 90's or 120's ought to put you back in the seat. As far as the towing side, 90's would be better. I'm only going to 50's or 75's to avoid the heat when towing.
CD
CD
dodgediesel
17
04-05-2011 11:21 AM
Stock 02
28
09-24-2006 11:09 AM
