twins oil line
Old 12-27-2006 | 06:39 PM
wldman32's Avatar
twins oil line
does anyone know how to run a second oil line for twins on a 03? i see the two plugs on top of the filter housing but they are too small for my ht3b fittings.thanks!
Old 12-27-2006 | 06:42 PM
PourinDiesel's Avatar
Get conversion pieces.
Old 12-28-2006 | 08:51 PM
wldman32's Avatar
i talked to a couple of people and they said i have to drill out the existing hole on top of the filter housing and tapp to 1/4 pipe .has any one here just used the hole without doing that?
Old 12-29-2006 | 06:11 PM
nickleinonen's Avatar
you can get all kinds of adapter fittings to fit 1/8" npt.. it will flow enough oil for a turbo our sized, but you could always bore it out and tap 1/4" npt or some orb size.. or you could put a tee fitting in the stock turbo feed line
the ge turbos i have at work have a ±3/16" restrictor fitting in the oil line to it [and those turbos are a lot bigger than ours]
dodgediesel
ABDTR #5
10-18-2011 10:22 PM
dodgediesel
ABDTR #5
496
10-16-2011 05:33 PM
dodgediesel
17
04-05-2011 12:21 PM
Tate
02-04-2008 02:17 AM
Stock 02
28
09-24-2006 12:09 PM
