twins
twins
I am new to this forum, and I am sure you guys have already answered this question before, so bare with me here. I have a 03' 3rd Gen w/ TST and diesel dynamics stage three injectors. I have a pusher pump and a Suncoast tranny. My question is Which Turbo should I use? Do I have to go with twins in order to run the Powermax on 9/9? I tow only lightly and am mostly interested in street race acceleration speed. Any info you guys can give me would be greatly appreciated
check with enterprise engine, They have a turbo that is surviving the TST and injectors in pulling comp. Its not on their website, you need to call and talk to them.
1 Post
My vote goes for twins. What horsepower level are you wanting to run at?
Its actually not that bad to drive, I usually run the box on 2/3 the smoke is not terrible unless I want it to be. I really don't have a specific horsepower goal, I really just want to be able to fully utilize the fuel (power) I already have. Could I go with a single and run nitrous on hard runs? or would I scatter the engine for sure. I realize running that kind of equipment there are some inherent risks assosiated with it, and I am willing to deal with them.
Forgive my ignorance, but If I go with twins will I still be able to use my truck as an everyday driver? Also, will twins take forever to spool up? I have never been around a truck with twins, but I understand the basic concept. Which turbos work well together?
Guest
Posts: n/a
Twins will spool better than a big single, make more power, and keep egt's cooler.
www.piersdiesel.com has one of the cleanest setups for guys who don't want to do their own plumbing and fabrication. Twins will usually make 50+psi or more boost, most people have their heads oringed so they don't blow a head gasket.
Twins actually make for a much better driving truck. One of the main goals with twins is to be able to run a big turbo without the drawbacks of slow spool-up. They have to be done right, though.
I have heard stories from others on the complications created by running mismatched turbos. I am certainly not the expert on this; I'm sure others will chime in here.
Originally posted by AK RAM
Good god man...with a SINGLE? I'd hate to have to drive that truck around town. That must be one mean sled puller though.
Re: twins
I have run the box as high as 6/5 but I usually run it on 2/3. I don't tow much but on hard runs I have seen temperatures as high as 1400. I have my shut down on the box set at 1300 the only time it got that high was when I disabled it once.
With that much fuel twins are definitely the way to go. They are more driveable have better cooling than any single will. Like mentioned, they must be setup right, so I would stick with one of the major vendors that have the R&D invested.
John
John
banshee,
How do you like your twins? What do you dyno at? Did you o-ring your head?
I think the general opinion is that twins are the way to go. The only drawback seems to be the cost.
