which twins????
Old 10-19-2007, 12:59 PM
dodgezilla04's Avatar
hi piers, glad to see that you are back around
Old 10-19-2007, 02:40 PM
Stainless's Avatar
Originally Posted by BlueDragonUSMC
You could do the A-3000 and A-5000, for under 5K, or you could do the New A-MST, from ATS, The price is 3550, and it comes with anything, and uses your stock turbo, 550 hp, with that setup, it sweet
MST is sweet, any idea on the release date?
Last edited by t-boe; 10-19-2007 at 04:33 PM. Reason: DO NOT USE OR REPOST PROFANITY WITH OR WITHOUT SYMBOLS!
Old 10-19-2007, 03:46 PM
jfranklin's Avatar
Originally Posted by jrussell
I think you're confusing a single stock turbo with a stock turbo run in a twins setup. At 40psi in a twins setup the stock turbo is only pushing about 20psi.
I thought the BD twins were proven to be too small for high HP applications?
700hp not enough for you???
Old 10-19-2007, 04:12 PM
jrussell's Avatar
Sure, but I've heard they won't keep things cool at 700. Others have said 600 is pushing it with the smaller set.
With just 90hp sticks and some boxes I doubt you're even close to 700 anyway.
Old 10-19-2007, 04:14 PM
JCLeary's Avatar
Don't hold your breath. It's been coming out for a couple of years now. Over two years ago they told me "oh, yeah, it'll be out in December. Just give us a call..."
Well, three turbos and a truck later it's still not here.
Someone, prove me wrong and show me one in action...
Please?!?!?!
Old 10-19-2007, 04:15 PM
jfranklin's Avatar
Sure, but I've heard they won't keep things cool at 700. Others have said 600 is pusing it with the smaller set.
im just saying a stock turbo and a new primary is going to be limited and i think the bd setup is more than most trucks will ever see and still very drivable..
Old 10-19-2007, 04:21 PM
jrussell's Avatar
Well, everything has limitations. Even a huge set of twins will only go so far.
AFAIK the stocker/S400 setup is good for a little more power than the smaller BD set. They're both going to be very driveable because they're both small setups.
Old 10-19-2007, 04:35 PM
t-boe's Avatar
Using a stocker in a twins setup is a heck of a lot cheaper too. $3k is better than $4,500 to $5k for a set.
Old 10-19-2007, 04:44 PM
THE 0NE's Avatar
so if i go through nathan do i get two turbos? or do i have to use my stock one?
Old 10-19-2007, 04:52 PM
depends on what set you go with. he will talk with you about your truck usage, power desires, and $. then make some recommendations.
Old 10-19-2007, 05:16 PM
THE 0NE's Avatar
i just got off the phone with dave from goerend so thats going on order next week. so not it time for the twins. dodgezilla did you do head studs?
Old 10-19-2007, 05:19 PM
Luvnacumns's Avatar
You don't have to have studs if your smarty I Don't have any.... But I am sure the head gasket will puke.. I plan on studs in the spring... In nathan's smaller towing set up you will use your stocker on top of an 71 mm S400 on the bigger towing set up a 62/13 with an 80 mm s480!! UMMM yeah chris I allready called Nathan... Guesss what bigger and better!!!
Old 10-19-2007, 05:47 PM
THE 0NE's Avatar
dodgezilla is the tq and hp you have in your sig with the rowing twins?
Old 10-19-2007, 05:53 PM
jfranklin's Avatar
maybe i dont post every mod in my sig including stereo,shocks,nav system and panty color i will leave that for others..
Old 10-19-2007, 05:59 PM
jaredb900rr's Avatar
So Shane, you're thinking of upgrading already?
Quick Reply: which twins????
