Twin turbos
Old 11-08-2007, 01:02 PM
MOJO1's Avatar
Question Twin turbos
Need some help i want a set that will boost down low but build big power.What do i need and who makes them and the and sizes? I know do a search but i want your input on this they are going on my 07 5.9 auto Thanks for your help!
Old 11-08-2007, 01:05 PM
Sloverado's Avatar
MPI has the lock down on the twins it seems. I have some twins but Rick Lance did all my plumming for the. He is the mod at Diesel Place. He did a very good job on my piping. I already had the turbo's. Call Nate at MPI he will hook you up.
Old 11-08-2007, 01:10 PM
MOJO1's Avatar
I need a number dont know MPI
Old 11-08-2007, 01:12 PM
DTR 1st Sergeant
soulezoo's Avatar
PM Idaho CTD here. Also visit twins club thread..
Old 11-08-2007, 01:13 PM
Winner winner chicken dinner!
RyeThomas's Avatar
http://www.maximizedperformanceinc.com/
Old 11-08-2007, 01:18 PM
DTR 1st Sergeant
soulezoo's Avatar
That is the holy grail of CTD and turbos!!! Lots of combos to be had out there without any empirical evidence as to which is better/best. There are a lot of opinions though. One thing I can comment on with some accuracy is that the mods a truck has will make different sets react differently-- just like the same mods on different trucks do different things. And another is that because a turbo makes a really good single, doesn't mean it will be good in a set of twins. And the last thing is... just because a particular turbo was good as a secondary with "model x primary" doesn't mean it will be worth a hoot with "model y primary". That is why lots of tuning goes on...
Just do some good old fashioned research and enjoy!
Old 11-08-2007, 02:25 PM
dodgezilla04's Avatar
i have a set of nathans older towing twins. they light off WAY faster than my sps62 did, almost feels like stock, they go right to 57psi and stay there.
Old 11-08-2007, 02:33 PM
MOJO1's Avatar
What about Relentless twins? They seem to a good set for the money? Is anybody running these twins? Just checking all the opptions.
Old 11-08-2007, 02:36 PM
DTR 1st Sergeant
soulezoo's Avatar
The new BD race twins are something to look at as well...
Piers is going to be developing a new set as well...
This is a good time to own a CTD and want twins!!
Old 11-08-2007, 06:46 PM
fjbiker86's Avatar
while we are on the subject of twins
For twins i understand that you need a second gen ex. manidold.....
1.) do i have to use a 3 piece manifold ?
2.) useing a 2nd gen ex. manifold do i need to run a 2nd gen turbo for the top turbo or will a 3rd gen turbo work?
sorry to thread hijack!
Old 11-08-2007, 06:54 PM
Luvnacumns's Avatar
MPI all the way.... I love mine...
fj to answer your questions
1.. no...
2. no too...
My twin set up is the stock turbo on top and then a s400 on the bottom... Vroom Vrooom!!! Nathan in my opioion(mpI) is the only way to go... Relentless is about the same but no where near the fit and finish!!
Old 11-08-2007, 06:56 PM
jrussell's Avatar
What do you consider "big power"? The stocker/S400 setup seems to handle 600hp pretty easily and spools like stock with aftermarket fueling.
Definitely give Nathan @ MPI a call before you buy anything. He's really done his homework when it comes to twins (and turbos in general).
Old 11-08-2007, 07:31 PM
fjbiker86's Avatar
luvna
thanks 4 the reply, where does your oil return line go on your bottom turbo? is it in the block where that plug is right above the pan?
Old 11-08-2007, 08:17 PM
trefling's Avatar
I like the ATS compound setup with the A2000 & A5000
Nice spool up down lown and not bad top end
Old 11-08-2007, 09:58 PM
Luvnacumns's Avatar
the oil return of the bottom turbo uses the stock existing return and the new "top" turbo uses a return in the front of the motor where you need to knock out a freeze plug... Don't ask me how i know that!!! and don't punch it trough and into your oil pan!!! you have to remove the whole motor to take the oil pan off!!!!Un less your lucky enough to get it out with a magnet!!!
Quick Reply: Twin turbos
