Turbo Whine
Turbo Whine
Recently had a magnaflow exhaust with a K@N intake installed and am real pleased with everything. Throttle response is better and the sound is awesome. I know I will catch some hell for this but here goes: I am not to crazy about the turbo whine that now screams through my truck. I was just wondering if I took the K@N out and put the factory airbox back, would it stop. Or is it the new exhaust with the free flowing muffler that causes this. Also, will I have any ill effects with the stock air box and new exhaust? I would appreciate any help. thanks!
You will not get as much benefit from just exhaust or just air intake. They work together to increase engine breathing, both in and out. Together they help lower EGTs and improve turbo spoolup. Keep the window up and radio louder until you get use to it.
I did the same took off the K@M intake and put the stock one back on and putin K@M replacement filter truck rounds good and I still here the Turbo but it's not as bad you can't go wrong by doing this the only thing your stock with a intake system.
Stock filter
Most of the guys are suggesting that you drill a 4" hole in the bottom of the stock box to improve the air inlet flow. This with a muffler upgrade seem to work fine.
