Turbo help
Turbo help
when pulling 23000# trailer i am getting very bad tubo shutter pulling up hills these are the numbers when it happens rpm1650 egt 1225 boostjumping around 18-25pounds stock turbo afe stage II banks technicooler system(bigger inter cooler, boost tubes and high ram) cant makes those same numbers or the turbo shutter with out the trailer. This is in 4th gear half throttle because egts are getting high, have more power but cant use it cause my egts. Can anyone explain what is going on or why. what can i do to get ride of this cause for what i know i dont think its good. Is it maybe just to much weight going up long step hills. Thanks
So no power adders?
If not you should be able to floor it without egt issues, especially with the technicooler and afe.
Downshift and see where that puts your rpms, 1650 is pretty low, it you hit 3rd you would be turnin 2000+ I think but should help egts, 1225 aint to high on egts though.
So no power adders?
Mine will do that too,, it is a case of learning how to drive around that rpm,, it is caused by a unbalance of air, to and from the turbo.
I just increased my hp so that I never hit that rpm, I like to pull in overdrive all the time and at 1950 it will do it on mine
Kevin
Kevin
Kevin
Kevin
you think that iam just pulling to much weight 23k plus cause the only thing i can do to help is drop gears and speed i get into or my egts get to high
Putting on the new turbo is what cured my egt problem. I dont think your weight is an issue, especially if it isnt a 5er, the problem with a 5er is the wind resistance. The only time through that whole last trip did my egts get even remotely high was when I had to drop into 3rd and then it would over rev. Hence now the extra hp to help eliminate the need to drop out of overdrive
Kevin
Kevin
CumminsRedneck
07-06-2013 03:20 PM
Haulin_in_Dixie
07-21-2003 11:14 AM
redram
12-10-2002 09:54 AM
